Holybro PM03D Power Module
  • controlled power supply, current consumption and battery voltage measurements
  • compatible with flight controllers using a 12C power monitor
  • XT-30 and XT-60 connectors
Not compatible with: Flight controllers that use analog power modules (Pixhawk4, Pixhawk4 Mini, pix32 V5 or Durandal).
The PM03D Power Module is compatible with flight controllers that use a 12C power monito (e.g. Pixhawk 5X or higher). It provides regulated power and battery voltage and current consumption measurements using the 12C digital protocol via a 6-pin 2.00mm CLIK-Mate cable. The PM03D is designed for multirotors such as the X500 V2. It has XT-30 as well as XT-60 connectors for the motor controller and battery. It also has two 5V BEC and a selectable 8V/12V output, which are available for various peripherals.
Note: This power module is not compatible with flight controllers that use analog power modules, such as Pixhawk4, Pixhawk4 Mini, pix32 or Durandal.
  • Plug&Play
  • for easy motor ESC connection: XT-30 connectors and solder pads
  • Onboard voltage regulator
  • 5 V/A connections
  • selectable 8V or 12V triple pin header
  • max. input voltage: 6S battery
  • rated current: 60A
  • max. current: 120A (<60sec.)
  • max. current measurement: 164A
  • Connections
    • XT-60, XT-30
    • Soldering pads (in each corner)
    • CLIK-Mate 2.00mm (5.2V/3A stand-alone BEC).
    • JST GH 4-pin (5.2V/3A, BEC shared with 5.2 three-row header)
    • 2 x three-row header (5.2V/3A, BEC together with JST GH 4-pin | 8V or 12V, 3A)
  • Dimension: 84 x 78 x 12 mm (without cable).
  • Mounting: 45 45 mm
  • Weight: 59g
Note: The XT60 connector and 12 AWG cable with which the PM03D is supplied are rated for 30 A continuous current and 60 A instantaneous current (< 1 minute). If a higher current is to be used, the connector type, as well as the cable size should be changed accordingly.
  • 1 x PM06 board
  • 1 x 80 mm XT60 connection cable (pre-soldered)
  • 1 x electrolytic capacitor: 220uF 63V (pre-soldered)
  • 1 x CLIK-Mate 6-pin cable with a distance of 2.00mm (power supply)
  • 4-pin JST GH feed connector (2.1 x 5.5 mm)
  • 4-pin JST GH mating connector (2.5 x 5.5 mm)
  • 4-pin JST GH to USB type C
  • 2 x 4-pin duplex cable
  • nylon spacer and nuts
Shipping weight: 0,21 kg
Item weight: 0,06 kg
Holybro PM03D Power Module Manual
€ 93,95
Docs MYBOTSHOP documentation
