Holybro M10 GPS Standard
  • SKU: MBS-SES-289-01
  • GTIN: 0658917501921
  • HAN: 12040
  • Category: UAV / Pixhawk
Holybro M10 GPS
  • different versions
  • Multi-constellation GNSS
  • Multiband RF front-end architecture
  • IST8310 compass
  • 115200 5Hz baud rate
Holybro's M10 GPS uses multi-constellation GNSS powered by the u-blox M10 series. This is a simultaneous GNSS receiver that can receive and track multiple GNSS systems. Due to the multiband RF front-end architecture, all four major GNSS constellations (GPS, Galileo, GLONASS and BeiDou) can be received simultaneously.
In addition, the GPS has an IST8310 compass, a three-color LED display, a buzzer, and a safety switch. This module is supplied with a baud rate of 115200 5Hz. The high gain patch antenna provides excellent performance, while the omni-directional antenna radiation pattern increases flexibility in device adjustment. It also features active circuitry for the ceramic patch antenna, as well as a rechargeable backup battery for warm starts.
Firmware support for M10 GPS:
  • PX4 1.14, ArduPilot 4.3, INAV 5.0.0, Betaflight 4.3.0 or newer is required.
  • As of September 7, 2023, PX4 1.14 RC1 (Release Candidate) has been released. Please check this link for the latest release details. More details about flashing the RC version can be found here.
Holybro M10 GPS (JST GHR1.25mm 10pin cable):
This option is the most common, it is used on the This connector can be used on Pixhawk Standard Flight Controller 10pin “GPS Module”or "GPS1" input port.
  • GNSS Receiver: Ublox M10
  • Compass: IST8310
  • Accuracy: 2,0m CEP
  • Default baud rate: 115200
  • Input voltage: 4,7 - 5,2V
  • Port type: JST-GH-10P
  • Weight: 32g
  • Other:
    • Tri-color LED
    • OnBoard Buzzer
    • Safety Switch
    • LNA MAX2659ELT+RF amplifier
    • Low noise 3,3V regulator
  • M10 GPS Module
Shipping weight: 0,10 kg
Item weight: 0,03 kg
€ 54,95
Others also bought:
Docs MYBOTSHOP documentation
