ArduCAM 12MP*4 Quadrascopic Bundle Kit for Raspberry Pi, Four IMX477
  • SKU: MBS-SES-192-13
  • GTIN: 0658917502720
  • HAN: B0397
  • Category: Sensors
ArduCAM NVIDIA Jetson Cameras
  • ArduCam cameras for the NVIDIA Jetson Developer Kits
  • 12MP IMX477 cameras with various attachments
With this Quad Camera Kit, you can use up to four 64MP autofocus cameras on a Raspberry Pi standard model. ArduCam's kit operates according to the standard in a four-channel mode, meaning that all cameras are configured to capture photos/videos at the same time.
Supported Modes
  • Single Channel (no synchronization): the four cameras operate sequentially, with one camera capturing after the other. Full-res for each.
  • Dual-Channel (synchronized): two cameras merge into a full-res frame, operating synchronously. 1/2 res for each.
  • Four-Channel (synchronized): all four cameras work in a full-res frame synchronously, 1/4 res for each.
Technical Specifications
Four-in-One Camera Setup:
  • Combines four cameras in one image.
  • Each camera provides a maximum resolution of 2028 (H) x 1520 (V).
Wide Compatibility:
  • Supports multi-platform multi-camera solutions, including Raspberry Pi, Jetson Nano, Xavier NX, and many other platforms.
Native Support for Raspberry Pi:
  • No additional driver installations required to use the camera kit with Raspberry Pi.
Versatile Applications:
  • Synchronized video streams with Raspberry Pi can be used for various applications, such as stitching, 3D sensing, tracking, and more.
Support for Advanced Applications:
  • Enables applications in areas such as Virtual Reality (VR), Augmented Reality (AR), and Simultaneous Localization and Mapping (SLAM).
Requirements for NVIDIA Jetson:
  • For JetsonL4t 35.x Jetpack 5.x and higher versions, the latest firmware of the CamArray Kit is required (not older than version 2023.02.03) to ensure full access. The kit can still be used on earlier JetPack versions.
Additional Information: The kit enables advanced applications and technologies like VR, AR, and SLAM, indicating a wide range of possible uses.
  • The synchronization of video streams provides a foundation for sophisticated applications that require precise coordination of cameras.
  • 4x 64MP Camera Modules
  • 1x UC-512 Camarray HAT
  • 4x 30cm 15-22pin Camera Cables
  • 1x 7cm 15-22pin Camera Cable
€ 439,95
Docs MYBOTSHOP documentation
