ArduCAM 2MP AR0230 OBISP MIPI Cam mit M12 Objektiv
  • SKU: MBS-SES-198-01
  • GTIN: 0618455044168
  • HAN: B0247
  • Category: Sensors
ArduCAM OBISP MIPI camera
  • 2 MP AR0230 HDR
  • Possess own hardware processor
  • up to 96dB
ISPs (Image Signal Processors) have long been a very specialized topic for camera systems. The problem is that today almost all cameras are RAW sensors and do not include an ISP for cost and power consumption reasons. Arducam's OBISP project aims to solve this problem. As the name suggests, it has an integrated ISP that has its own hardware processor and does not rely on the processing power of the backend processor. along with the OBISP camera, users can use better cameras on Arduino, Raspberry Pi and Jetson Nano.
The first two OBISP cameras released are the high-resolution 13 MP AR1335 camera and 2 MP AR0230 HDR camera. They use standard 15-pin RPI/Jetson Nano MIPI camera flex cable for use with Raspberry Pi and Jetson Nano/Xavier NX with Arducam's V4L2 kernel driver framework.
The ArduCAM 2 AR0230 OBISP MIPI Cam with M12 lens has an integrated ISP (Image Signal Processor) with a very good highlight contrast HDR performance. This has a dynamic range of up to 96dB. The standard Raspberry Pi Zero 22pin MIPI CSI-2 interface is used. This module is designed to work on Raspberry Pi and Jetson Nano. However, it can also be ported to other MIPI CSI-2 interface compatible platforms.The camera driver is kernel dependent. If an upgrade or downgrade is done this must also be done with the other side.
Applications for the 2MP camera include cell phones, digital still cameras, PC and IoT cameras, and facial recognition systems.
Technical data:
  • Resolution: 2MP 1920x1080
  • Trigger type: rolling shutter
  • IR: built-in 650nm IR filter, visible light only.
  • Night vision capability: optional with suitable lens combination
  • Interface: 2-lane MIPI CSI-2
  • ISP function: AWB, AE, Flip, Mirror, Gamma, Sharpness, Saturation, etc.
  • Platform support: Raspberry Pi, Jetson Nano or other platform with MIPI CSI-2 interface
  • Sensor type: AR0230
  • Pixel size: 3.0um x 3.0um
  • optical size: 1/2.7"
  • Lens: M12 (EFL: 4mm, FoV(H): 90°, F/NO: 2.8, Distortion: 3%)
  • Bildrate: 30fps@1920x1080/1280x720/640x480/320x240
  • Dynamic range: up to 96dB
  • Sensitivity: 4.0V/ lux-sec
  • SNRmax: 41dB
  • Temperature range: -10°C - 70°C
  • Current consumption: max. 300mA@3,3V
  • Camera driver: V4L2 compliant driver for Raspberry Pi and Jetson Nano
  • Board size: 40mm x 40mm
  • Powerline frequency: 50Hz, fixed
Scope of delivery:
  • 1 x ArduCam 2MP AR0230 OBISP MIPI Cam with M12 lens.
  • 1 x 80mm 22pin FPC cable
Contact data
€ 74,95
  • Currently out of stock
Docs MYBOTSHOP documentation
