ArduCAM 5MP M-Focus Pi Cam with Case
  • SKU: MBS-SES-185-17
  • GTIN: 0618455052125
  • HAN: B0176
  • Category: Sensors
  • Software-controlled movable lens
  • Precise manual focus control
  • Capture objects in the millimeter range and in the distance with the same camera
  • Autofocus Python scripts
  • Supports autofocus features on Raspberry Pi 4/3B+/3 and more
  • Natural vision thanks to 5MP OV5647 sensor camera module
The ArduCAM team has released a series of camera modules for the Raspberry Pi, including 5MP and 8MP modules. They are fully compatible with the official version and are divided into Standard Version, Optimized Optical Performance Version, Miniature Spy Camera Version, NoIR Version, Motorized IR Cut Version and Programmable Motorized Focus Camera Version. These camera modules support all Raspberry Pi models and require a 15-to-22 pin cable or adapter to work with the Pi Zero.
The official camera modules have fixed focus lenses that are either glued or need to be manually adjusted. However, Arducam believes that your focus is important and has released this motorized focus camera for Raspberry Pi. With this Arducam camera module, you can control the focus of a camera for the Raspberry Pi via software so you can get closer and see what you want to see.
To learn more about autofocus with Raspberry Pi camera modules, we recommend the book Raspberry Pi Camera Autofocus: The Complete Guide (English only).
Application:
  • IoT Cameras
  • Robot Cameras
  • Wildlife Cameras
  • Other battery powered products
  • Can be used in MCU, Raspberry Pi, ARM, DSP, FPGA platforms
Technical Data:
  • Sensor: 5MP OV5647
  • Still image: 2592×1944 Max
  • IR Sensitivity: Built-in IR filter, visible light only
  • Focus type: Motorized focus
  • Field of view: 54°×44° (H×V)
  • Plate size: 25mm × 24mm
  • Focus distance: 80mm to infinity
Scope of delivery:
  • 1 × 5MP OV5647 camera board with motorized lens for Raspberry Pi
  • 1 × Acrylic case for the camera module
  • 1 × 15cm flexible ribbon cable for Raspberry Pi model A and B (Pi Zero cable not included)
€ 25,95
Docs MYBOTSHOP documentation
