ArduCAM Raspberry Pi cameras NoIR Version Standard 16MP With Board
  • SKU: MBS-SES-185-33
  • GTIN: 0618455052569
  • HAN: B0386
  • Category: Sensors
  • Sensor Sony IMX519
  • 16 megapixel
  • Lens: f/1.75; EFL: 4.28; FoV: 80°
  • without IR filter, IR sensitive
The high-resolution 16MP IMX519 (NOIR) camera from Arducam is an exclusive camera board, specially developed for use with Raspberry Pi V1, V2 and with a very high quality standard.
It does not compromise on technical specifications. With a resolution of 16 megapixels (compared to 8MP and 12MP), a standard lens, a V2-like form factor and a host of enhancements, the camera offers a better choice for a whole range of industrial/consumer etc. applications. It is compatible with all existing Pi models, works with the latest Foundation software and uses the same tuning algorithms used in the o?cial camera modules.
16MP for all Pis
The new Raspberry Pi camera features a 16MP Sony IMX519 sensor with a pixel resolution of 4656 x 3496, double that of the v2 camera and 40% higher than the HQ camera; it is compatible with any Raspberry Pi board with a MIPI/CSI interface and runs directly on the Raspberry Pi OS without much configuration.
Crisper Images/Video
The 16-megapixel camera can record 1080p Full HD video at up to 30 frames per second and 720p HD video at up to 60 frames per second, and also offers an effective 80-degree field of view.
V1/V2 Size
The camera module is the same size as the pi camera V2, the package comes with plastic housing, also suitable for V1 and V2 boards.
Technical Datas:
  • Sensor Sony IMX519 stacked, back-illuminated sensor 16 megapixels 1.22 µm × 1.22 µm pixel size7.103 mm diagonal (Type 1/2.534)
  • Output: RAW10/8, COMP8
  • IR cut Filter: without IR Filter, IR sensitive
  • Video Modes: 1080p@30fps, 720p@60fps
  • Linux integration: V4L2 driver available
  • Ribbon Cable Length: 150mm
Scope of delivery:
  • 1x Sony IMX519 Sensor
  • 1x Standard objective
  • 1x FPC Cable
€ 44,95
Others also bought:
