Arducam 1/1.32″ 64MP Auto Focus Camera Module for Raspberry Pi
  • SKU: MBS-SES-313
  • GTIN: 0658917503420
  • HAN: B0483
  • Category: Sensors
  • Simple configuration thanks to native libcamera support.
  • Ultra-high resolution: Largest sensor camera for Raspberry Pi.
  • 10x digital zoom and up to 900 seconds exposure time at maximum resolution.
  • Flexible focus: Automatically, manually, continuously adjustable.
  • Compact and compatible: ABS housing, size 24 x 25 mm (v1/v2 compatible).
Summary
The latest 64-megapixel camera from Arducam sets new standards with the largest available sensor size for Raspberry Pi cameras and an impressive resolution of 9248 x 6944 pixels. Additionally, it offers an impressive 10x digital zoom, enabling flexible composition and capturing of subjects at various distances. Furthermore, the product features a maximum exposure time of 900 seconds at maximum resolution. This sensor size ensures exceptional light sensitivity, even in challenging lighting conditions.
This camera ensures smooth compatibility with libcamera, providing Raspberry Pi users with effortless usage. No cumbersome configuration with different files is required - a true plug-and-play solution.
The camera offers various focus options, including autofocus, manual focus, and continuous focus. Whether you desire precise focus control or prefer a simpler approach, this camera can meet individual requirements.
Application
  • Wildlife photography
  • Machine learning
  • Home security system
  • AI applications
  • DSLR camera control
  • Plug-and-play with libcamera: Native support, effortless setup, no configuration changes required for immediate use.
  • Largest sensor, excellent light sensitivity: The huge 9248x6944 sensor is superb, ideal for night photography.
  • 64 MP and 10x digital zoom: High-resolution 64 MP and 10x digital zoom for flawless details.
  • Flexible focus options: Automatic, manual, and continuous focus options for different environments.
  • Compact and compatible design: Small size of 24 x 25 mm with ABS housing and tripod compatibility (UB0224) for seamless use.
Specifications
Image Sensor
  • Image sensor: OV64A40
  • Still resolution: 64 megapixels
  • Color filter type: Color
  • Shutter type: Rolling
  • Optical size: 1/1.32"
  • Pixel size: 1.008 μm x 1.008 μm
  • Active area of sensor: 9248 (H) x 6944 (V)
  • Output format: JPEG/YUV/RGB/RAW10
Video Modes (on Raspberry Pi)
  • 1080p30, 720p60, and 640x480p60/90
Video Modes (Camera Module)
  • 9152x6944@2fps, 8000x6000@2.5fps, 4624x3472@7.6fps, 3840x2160@14.8fps, 2312x1736@26.7fps, 1920x1080@45fps
IR Sensitivity
  • Integrated IR cut filter, visible light only
Lens
  • Focusing type: Manual/Auto
  • Focal length: 6.65 mm
  • F.NR: F1.9
  • Field of view (FOV): 84°(T) x 68°(H) x 56°(V)
  • Lens mount: Standard lens
  • Standard focus range: 12cm~∞
Electrical and Mechanical
  • Power requirements: 3.3 V/300 mA
  • Camera board size: 25 x 24 mm
Functionality and Compatibility
  • Supported operating system: Raspberry Pi OS (Bullseye)
  • Supported platforms*: Raspberry Pi 5/4B/3B+/3/2/CM3/CM4/Zero W/Zero 2 W
*Raspberry Pi 2/3/Zero W may not be able to activate maximum resolution due to memory constraints. Please ensure your platform has at least 1 GB of memory. Achieving maximum resolution on Pi 4 and CM4 may be affected by CMA, which can be resolved by switching from GUI mode to terminal mode.
Package Contents
  • 1 x 64MP camera module
  • 1 x 15 cm 15–22-pin FPC
  • 1 x 15 cm 15–15-pin FFC
Others (1)
Schnellstartanleitung
PDF (2)
Arducam OwlSight OV64A40 Kameramodul – Produktbeschreibung
Arducam OwlSight OV64A40 Kameramodul – Benutzerhandbuch
€ 85,99
