ArduCam All-in-one Raspberry Pi AI Camera Kit
  • SKU: MBS-SES-185-42
  • GTIN: 658917504861
  • HAN: B0572
  • Category: Sensors
Arducam All-in-One Raspberry Pi AI Camera Kit
  • with CM5 inside
  • Outdoor Security IP66 Camera Kit
  • PoE Power
The Arducam All-in-One Raspberry Pi AI Camera Kit (B0572) is a fully integrated edge AI security camera for outdoor use, combining a 12.3 MP Sony IMX500 AI vision sensor with a pre-installed Raspberry Pi Compute Module 5 (CM5) in an IP66-certified metal enclosure. The Sony IMX500 combines image sensing and AI inference on a single chip, enabling true edge AI processing directly on the camera – without cloud connectivity and with maximum data privacy.
The camera is powered exclusively via PoE (Power over Ethernet) and supports installations over 100 metres without dedicated power infrastructure. The IP66 enclosure is dust-, water-, and fog-proof and designed for reliable continuous operation in demanding outdoor environments. Supported use cases include intelligent perimeter security, construction site monitoring, traffic and parking enforcement, and crowd analytics in public spaces.
The camera runs Raspberry Pi OS and supports Arducam's IMX500 AI Model Zoo with pre-trained models for object detection, pose estimation, and segmentation. Since AI inference runs directly on the IMX500 sensor, the CM5 is fully available for application logic, network communication, and data storage.
Technical Data
Computing Unit
Compute Module Raspberry Pi CM5 (default: CM5004016, 4 GB RAM, 16 GB eMMC, no Wi-Fi/Bluetooth)
Operating System Raspberry Pi OS (pre-installed)
Image Sensor
Sensor Sony IMX500 Intelligent Vision Sensor
Resolution 12.3 MP (4056 × 3040)
Optical Size 1/2.3″
Pixel Size 1.55 µm × 1.55 µm
Output Format RAW10 (platform output: JPEG, YUV, RGB)
Video Modes 4056 × 3040 @ 10 fps | 2028 × 1520 @ 30 fps
Shutter Type Rolling Shutter
Optics
Focus Fixed focus (20 cm – ∞)
Focal Length 4.7 mm
Aperture F1.79
Field of View (FoV) 78° (D) × 66.3° (H) × 52.3° (V)
IR Filter Integrated 650 nm IR cut filter (visible light only)
Network & Power
Network Ethernet with PoE (no Wi-Fi / Bluetooth)
PoE Standard IEEE 802.3at / 50 – 57 V / 600 mA
Max. Power Consumption 15 W
Mechanical Properties
Dimensions 153.05 × 82.09 × 79.10 mm
Enclosure Metal, IP66 (dust-, water-, and fog-proof)
Environmental Conditions
Operating Temperature −20 °C – +75 °C (image stability guaranteed: 0 – 50 °C)
Storage Temperature −10 °C – +75 °C
Certifications
Standards CE, RoHS
Software & AI
AI Model Zoo Arducam IMX500 AI Model Zoo (object detection, pose estimation, segmentation and more)
AI Platform Sony AITRIOS™ compatible
Scope of Delivery
  • 1× Arducam All-in-One Raspberry Pi AI Camera Kit (B0572, IP66 outdoor) incl. pre-installed Raspberry Pi CM5
  • 1× Ethernet cable (1 m)
  • Note: PoE switch/injector, mounting bracket, and tripod are not included
€ 524,95
