ArduCam OV7251 0.3MP GS USB Camera Evaluation Kit
  • SKU: MBS-SES-345
  • GTIN: 0658917513368
  • HAN: EK022
  • Category: Sensors
Arducam OV7251 0.3MP Global Shutter USB Camera Evaluation Kit
  • 1/7.5-inch Monochrome Camera Module
  • USB3.0 Camera Shield Plus
To make it easier for customers to evaluate cameras or build a prototype with their own circuits without having to deal with complex details such as fine pin-pitch flex cables or solder balls, Arducam has developed a practical evaluation kit. This kit includes camera breakout boards as well as the Arducam USB2/USB3 camera interface and enables use without the need for programming skills.
The Arducam OV7251 MIPI monochrome (black and white) global shutter VGA camera module is specifically designed for use with Raspberry Pi boards. It can be connected directly to the CSI-2 camera interface of the Raspberry Pi without the need for additional hardware. The module is based on the 1/7.5-inch Omnivision OV7251 image sensor, which uses OmniPixel3-GS™ technology. It delivers 8/10-bit MIPI images in full frame, subsample and windowed mode and supports frame rates of up to 100 fps at VGA resolution. At the same time, it offers extensive image quality control options.
Thanks to the global shutter and the sensor's excellent light sensitivity, the camera is suitable for applications such as gesture recognition, head and eye tracking as well as depth and motion detection.
  • Sensor: Monochrome global shutter OV7251
  • Pixel Size: 3 μm x 3 μm
  • Active array size: 640*480
  • Optical Size: 1/7.5 inch
  • EFL: 1.3mm
  • F.NO: 2.2
  • IR Sensitivity: build-in 650nm IR cut filter (Check IR sensitive version with SKU EK028)
  • FOV: D86.5 Deg./H72.9 Deg./V57.7 Deg.
  • Focusing Range: 65mm ~ infinite
  • Output interface: 1-lane MIPI serial output
  • Output formats: 8/10-bit BW RAW
  • Maximum image transfer rate: 640 x 480: 210 fps
  • Board Size: 40mm x 40mm
Application
  • Cellular phones
  • Toys
  • Tablets
  • Machine vision
  • ARM/FPGA/DSP based platforms
  • 1 pcs Arducam OV7251 1/7.5-inch Monochrome Camera Module
  • 1 pcs Arducam USB3.0 Camera Shield plus
  • 1 pcs USB3 Cable
€ 259,95
Docs MYBOTSHOP documentation
