Arduino CAN Bus Shield
  • SKU: MBS-SH-28
  • GTIN: 0096718606849
  • HAN: ELE-CAN-BUS-SHIELD-V1.5
  • Category: Expansion Boards
Arduino compatible CAN BUS Shield
  • Arduino Uno, Leonardo, Mega, Due etc. compatible
  • CAN Bus Shield with up to 1Mbit/s
CAN-BUS is a widely used industrial bus, which is characterized by its long range, medium communication speed and high reliability. It is widely used as a diagnostic bus in the automotive industry and is also widely used in modern machine tools. This CAN bus shield makes the Arduino CAN bus capable. It uses Microchip MCP2515 CAN controller with MCP2551 CAN transceiver, CAN connection is made via standard 9-way sub-D for use with OBD-II cable, ideal for automotive CAN applications. The shield also features a micro SD card holder that allows you to save diagnostic information directly to the SD card, making this shield ideal for data logging applications.
  • Compatible with Arduino Mega and Leonardo
  • Implements CAN V2.0B with up to 1 Mb/s S
  • PI interface with up to 10 MHz
  • Standard (11 bit) and extended (29 bit) data and remote frames
  • Two receive buffers with prioritized message memory 9-pin Sub-D connector according to
  • industry standard
  • Two LED indicators
  • SD card holder for information storage
Links
  • Documentation
  • PCB Design Files
  • 1 x CAN BUS Shield
Shipping weight: 0,20 kg
Item weight: 0,10 kg
€ 19,95
