DOBOT Sliding Rail Kit Linear axis
  • Linear Axis for the DOBOT Magician
  • 1000mm Travel length
  • high positioning accuracy
  • up to 5Kg payload
The DOBOT Sliding Rail Kit is an linear axis kit for the DOBOT Magician robotic arm. The robotic arm is screwed on the linear axis and can operate on a travel length of 1000mm. The steering can be done via the current DOBOT Software-Version wich can be donwloaded for free on the DOBOT website (dobot.cc). The well concieved software enviroment in combination with the linear axis that has been milled very precisely result in the DOBOT Sliding Rail Kit beeing able to fit in a large variety of possible applications.
  • Payload: 5Kg
  • Travel length: 1000mm
  • Travel speed: Up to 150mm/s
  • Acceleration: Up to 150mm/s²
  • Positioning: Up to 0,25mm
  • Net weight: 4,7Kg
  • Weight incl. case: 7,23Kg
  • Dimensions: 1320 x 120 x 55mm
  • 1 x DOBOT Sliding Rai Kit
Shipping weight: 10,00 kg
Item weight: 4,70 kg
€ 1.299,95
