Electromagnetic brake MAB SLIM
Electromagnetic Brake MAB SLIM
  • MAB SLIM is an ultra-thin brake series
  • Power Supply: 24-48 VDC
  • Holding Torque: 0.06-38 (Nm)
The MAB SLIM v2.0 is a series of ultra-thin electromagnetic brakes developed specifically for mobile robotics applications. The brakes work on the power-off principle (spring force): they hold when de-energized and thus provide high holding torque at low power consumption – ideal as a safety/holding brake that secures the position even in the event of a power failure.
When current flows through the coil, the magnetic field generates a force that pulls the armature against the spring force and releases the brake (free movement). When de-energized, the springs press the armature and generate the friction force that closes the brake. The modular series covers a wide holding-torque range from 0.06 to 38 Nm and operates on 24–60 VDC.
The SLIM series is compatible with the MAB MD Series motor controllers and must be operated with an overexcitation controller, which is included in the set. On request, an actuator with a built-in electromagnetic brake is also available.
Technical data (series)
Type electromagnetic brake, ultra-thin; power-off (spring-applied)
Operating principle holds when de-energized; releases when voltage is applied
Holding torque (series) 0.06–38 Nm (model-dependent)
Nominal input voltage 24–48 VDC
Max. input voltage range 10–60 VDC
Brake current 2.3 A @ 25 °C
Current consumption (logic) 7 mA
PWM frequency 20 kHz
PWM duty cycle 10–90 %
Operating temperature range 0–80 °C
Control overexcitation controller required (included in the set)
Compatibility MAB MD Series motor controllers
Features high holding torque, low power consumption, very flat design
Additional documents 3D models; "MD Series × Electromagnetic Brake" documentation
  • 1× MAB SLIM v2.0 electromagnetic brake (selected version 01A–10A)
  • 1× overexcitation controller
Price on request
