HOKUYO UST-Series LiDAR UST-20LX-H01
- SKU: MBS-SES-17-04
- GTIN: 0618455051791
- Category: Sensors
Manufacturers:
Hokuyo UST-Series
- 10-20m Range
- 270° View
- IP65 Protection
- 40Hz Scan frequency
- Ethernet 100BASE-TX Interface
The Hokuyo UST-Series provides a series of high-performance LiDARs wich can be used for high demanding research or industrial usage in the field of automatization technique. Due to the small footprint of only a few centimeters wich comes with a scan range that is higher than average with 40Hz, The LiDAR is often used for UGVs. Therefore one LiDAR is attached at the front right corner and one at the back left corner to create a virtual safety zone around the vehicle. The founded data can then be used in ROS or other middlewares with other fitting algorithms for collision avoidance, SLAM or autonome navigation. For safety-critical applications we recommend the HOKUYO UAM-05 wich can be obtained on our site but requires you to make contact with us first of.
Dimensions
Please select the UST-LiDAR of your choice in the dropdown that can be found above to see the fitting technical data.
- 1 x HOKUYO UST-20LX-H01
| Item information | Value |
| Shipping weight: | 0,23 kg |
| Item weight: | 0,18 kg |
