Holybro H-RTK ZED-F9P Rover (RM3100 Compass) UART 10-pin (GPS1 Port)
  • UART 10-pin (GPS1 port)
  • UART 6-pin (GPS2 port)
  • DroneCAN 4-pin (CAN port)
  • Effective EMI shielding
  • Advanced signal processing
The H-RTK ZED-F9P Rover is an upgraded version of the original H-RTK F9P Rover. This RTK GPS module is equipped with the u-blox ZED-F9P GNSS receiver, the RM3100 compass, and a tri-color LED indicator, providing precise positioning and orientation data. With its IP66 certification, the module is reliably protected against dust and water, making it ideal for use in demanding environments.
The RTK GPS supports multi-band RTK technology with fast convergence times and consistent performance. It can simultaneously receive signals from GPS (L1 & L2), GLONASS, Galileo, and BeiDou, ensuring precise and reliable positioning. When used with a base station or an NTRIP service, it achieves centimeter-level accuracy. Additionally, the DroneCAN option provides features like MCU, IMU, barometer, and stable communication for advanced UAV system integration.
The highly precise PNI RM3100 compass ensures exact orientation and stability, offering outstanding reliability—ideal for complex UAV applications. It delivers high resolution, low power consumption, strong signal-to-noise immunity, a wide dynamic range, and high sampling rates. Its measurements remain stable over temperature variations and are free from drift effects.
  • High-Precision GNSS Receiver: Equipped with the u-blox ZED-F9P GNSS receiver for maximum accuracy.
  • Integrated RM3100 Compass: Ensures precise orientation and high stability.
  • Powerful Antenna: Dual-band antenna with high gain for optimized signal reception across GNSS frequencies.
  • Rugged Housing: IP66-certified for protection against dust and water, ideal for challenging environments.
  • Advanced Signal Processing: Hybrid coupler design combining SAW and LNA for enhanced signal quality and effective interference suppression.
  • Effective EMI Shielding: Minimizes electromagnetic interference for consistent signal stability.
  • Flexible Installation Options: Easy mounting on flat surfaces or elevated brackets for optimal positioning.
  • DroneCAN Option: Includes additional features like MCU, IMU, barometer, and robust communication interfaces for advanced UAV integrations.
Connector Type GH1.25 10pin cable  GH1.25 6pin cable  GH1.25 4pin cable
Applicable Ports Holybro GPS1 Port Holybro or Cubepilot GPS2 Port  Flight Controller CAN Port
Communication Protocol UART UART DroneCAN
MCU
IMU
Barometer
N/A N/A
  • STM32G4
  • ICM42688
  • ICP20100
*Pending support
Magnetometer High precision, Low Noise RM3100 Compass
Application Moving Station
(Aircraft, Ground Vehicle, Marine Vehicle, etc)
GNSS Receiver U-blox ZED-F9P High Precision GNSS Receiver
GNSS Band
  • GPS: L1C/A and L2C
  • GLONASS: L1OF and L2OF
  • Galileo: E1-B/C and E5b
  • BeiDou: B1I and B2I
  • QZSS: L1C/A and L2C
Number of concurrent GNSS 4
Heading accuracy 0.4 degrees
Positioning Accuracy Horizontal & Vertical: RTK 0.01m +1ppm CEP
Antenna
  • Dual-Band Stacked Ceramic Patch Antenna ( 47.5*47.5*4mm)
  • 20.5±1dB LNA Gain (typical)
Antennas Peak Gain (MAX)
  • L1: 4.0dBi
  • L2:1.0 dBi
Acquisition
  • Hot Start: 2s
  • Aided starts: 2s
  • Cold starts: 25s
Data and Update Rate
  • RAW: 20Hz Max
  • RTK: 8Hz Max
  • Moving Base RTK: 5Hz Max
Maximum altitude
  • 80,000 m
Maximum speed
  • 500 m/s
Sensitivity
  • Tracking & Navigation: –167 dBm
  • Cold starts: –148 dBm
  • Hot starts: –157 dBm
  • Reacquisition: –160 dBm
Timepulse Configurable from 0.25hz to 10mhz
Protocols NMEA、UBX binary、RTCM 3.3
Filtering & Amplication Triple SAW + LNA Filtering for Precise Signal Filtering & Signal Amplification
Double Hybrid Coupler for Efficient Signal Coupling
Anti-jamming Active CW Detection and Removal
Onboard Band Pass Filter
Anti-spoofing Advanced Anti-spoofing Algorithms
Cable Length 40cm
Baud rate: 115200 5Hz (default) can be set
Working Temperature -40 °C to +85 °C
Working voltage: 4.75V~5.25V
Current Consumption ~250mA
Dimensions Diameter: 78mm Height: 22mm
IP Rating IP66
Weight 117g
  • 1x H-RTK ZED-F9P Rover
  • 1x Fixed Carbon Fiber GPS mount
Shipping weight: 0,60 kg
Item weight: 0,12 kg
Port
€ 469,95
