Holybro Kakute F4 V2.4 Stacks 65A
  • SKU: MBS-ENTB-89-03
  • GTIN: 0658917501631
  • HAN: 20210
  • Category: Pixhawk
Holybro Kakute F4 v2.4 Stacks
  • Four Stacks
  • Plug-and-Play
  • DJI HD ready
  • 5x UART-connectors
  • 4in1 ESC Ports
  • 5V and 9V BEC
The Holybro Kakute F4 v2.4 Flight Controller includes a plug-and-play DJI O3 HD camera connector, 4in1 ESC ports, a barometer, OSD, 5x UART, logging capability with built-in flash, 5V and 9V/3A BEC, a simple solder layout, etc. The HD video transmitter draws power via the built-in 9V regulator. Due to the built-in barometer, it can also be used for autonomous flight.
  • New and fast F4 MCU with 150Mhz
  • 6x dedicated UART ports with built-in inversion for peripherals
  • PWM frequency: 16k to 96k
  • Separate drive and control circuitry
  • 2x plug-and-play 4in1 ESC connectors
  • integrated BetaFlight OSD (to show various data on the FPV display)
  • built-in barometer
  • LED & Buzzer Pad, 12C Pad (SDA & SCL) for external GPS/Magnetometer
  • 5V and 9V BEC
  • Continuous Current: 50A x4
  • Burst Current: 60A x4
  • Supports 4-6S battery
  • Supports DShot 150/300/600/1200 & MultiShot/OneShot/Proshot/PWM etc.
  • ESC telemetry Supported
  • Onboard analog current sensor
  • No output BEC
  • BLHeli_32 firmware
  • 1000uf 35v capacitor included (highly recommended for 6s setup)
  • Amperage meter scale ratio: 168
  • Dimensions: 48x37x6mm / Weight: 13.8g
  • Mounting holes: M4 30.5x30.5mm (M3 grommets included)
  • 1x  Kakute F4 V2 STACK
  • 1x  Electrolytic capacito: 1000uF 35v
  • 1x  8pin to 8pin 1mm pitch 65mm cable
  • 1x  8pin to 8pin 1mm pitch 25mm cable
  • 1x  JST SH 6pin to JST GHR 8pin 80mm &150mm cable (for DJI/Caddx HD System)
  • 1x  JST SH 6pin 100mm cable(for Caddx HD Systems)
Shipping weight: 0,20 kg
Item weight: 0,02 kg
Ampere
with or without Atlatl HV VTx
€ 154,95
