IQ-Motor Brushless Speed Module
IQ-Control Speed Module
  • Optimized for UAV & Pixhawk
  • Motor KV: 2200RPM/V
  • Max voltage: 6S (25.2V)
  • Torque: 130N/mm
  • Current consumption: 30A continuous & 60A peak current
The IQ-Control technology combines the high-speed brushless motor with the very precise stepper motor. In addition, both motors also require a corresponding power driver (H-Bridge), unlike the IQ-Motion Module. The IQ-Control technology integrates a very precise encoder with a powerful 32-bit motor driver in the motor. As a result, the IQ-Motion Module can be controlled with PWM, TTL, D-Shot & Multishot, but can also be flashed with the speed or position Firmware.
  • Position Module: Low speed / higher torque (positions controllable)
  • Speed Module: High speed / low torque (position monitored)
Special Features:
In addition to the special feature of switching between the position & speed firmware, this IQ module has many other features:
  • Regenerative & Active Brake
  • 3D-capable with almost no delay (change of direction of rotation)
  • High FET gate switching for particularly high efficiency
  • Flight time extension of up to 50% possible
  • 1 x IQ-Motion Module
PDF (4)
IQ-Control Speed Module Datasheet
IQ-Control Speed Communication Manual
IQ-Control Speed Instruction Manual
IQ-Control Speed Module Errata
€ 159,95
Docs MYBOTSHOP documentation
