Intel® RealSense Depth Modul D415
  • SKU: MBS-SES-144
  • GTIN: 0618455047343
  • HAN: 82635DSASRCPRQ 952000
  • Category: 3D Machine Vision
Intel® RealSense™ Depth Module D415 (BULK)
  • Intel®RealSense™
  • up to 1920 x 1080 RGB resolution
  • diagonal field of view over 70°
  • two global shutter sensors for depth streaming at up to 60 frames/s
  • range 0.3 m to over 10 m (varies depending on lighting conditions)
  • 50pin connector
Software
  • Intel®RealSense™
  • 50 pin connector
  • Intel RealSense Depth Module D415 (BULK)
Intel® RealSense Depth Modul D415 Datasheet
€ 359,95
