LIPSedge DL All Purpose 3D ToF Camera
LIPSedge™ DL All Purpose 3D ToF Camera
  • Versatile 3D ToF camera with USB 3.0 Plug & Play for Windows and Linux.
  • Short-to-mid range detection from 20 cm to 4 meters with high accuracy.
  • Edge Emitting Laser technology for wider and broader reach in various applications.
  • Supports gaming, entertainment, gesture recognition, and machine vision applications.
  • UVC standard for easy integration without bottlenecks, working straight out of the box.
The LIPSedge™ DL All Purpose 3D ToF Camera is a versatile, plug-and-play 3D depth camera that provides both 2D and 3D data in real-time with high depth resolution. With its user-friendly USB 3.0 plug-and-play functionality for Windows and Linux, it is the perfect solution for a variety of applications, including gaming, entertainment, medical applications, and machine vision. The camera offers precise and quick response when capturing 3D data and is especially suitable for gesture-based interaction and motion control. Thanks to the Edge Emitting Laser technology, it offers a wide range and high accuracy.
The LIPSedge™ DL utilizes Time-of-Flight (ToF) technology for precise distance measurement in the near and mid-range (20 cm to 4 m) and is resistant to ambient light, making it suitable for use in a variety of lighting conditions. It is ideal for applications that require non-invasive capture and real-time data processing. With standard UVC support, it allows integration into systems without additional drivers or software bottlenecks, so the camera is functional immediately after being plugged in.
LIPSedge DL Point Cloud
Hand Gesture
Body Skeleton
Technical Specifications
  • Technology: Time-of-Flight (ToF)
  • Min. Working Distance: 0.16 m
  • Max. Working Distance: 4 m (Normal mode), 1 m (Close mode)
  • Frame Rate: 320x240 at 30 FPS (native), 640x480 at 30 FPS (standard)
  • Z-Accuracy: ≤3% (depending on distance)
  • FOV (W x H x D): 74.2° x 58.1° x 88°
  • Shutter Type: Rolling Shutter
  • RGB Resolution: 1920x1080 at 30 FPS
  • RGB FOV (W x H x D): 79.1° x 50° x 88°
  • Illumination: Edge Emitting Laser x 2, Wavelength 850 nm
  • Power Supply: 6W (via USB Type A cable)
  • Temperature Range: 0 ~ 40°C (operation), -20 ~ 60°C (storage)
  • Dimensions: 112 x 36.6 x 27 mm
  • Ambient Light Compensation: Resistant to varying light conditions
  • Interface: USB 3.0 Micro-B
Included in the Package
  • LIPSedge™ DL All Purpose 3D ToF Camera
  • USB 3.0 Cable (Type A to Micro-B)
Others (2)
Download Center
GitHub ROS Wrapper
€ 414,95
