LinkerBot Linker Gloves
  • SKU: MBS-SES-435
  • GTIN: 0658917504977
  • Category: Sensors
  • Precise motion capture with 15 magnetic encoders
  • Wireless 2.4 GHz transmission with haptic feedback
  • Compatible with Linker Hand O7, L10, L20, L25 and ROS/ROS2
Linkerbot Motion Capture Glove – Precise Data Glove for Teleoperation and Robotics
The Linkerbot Motion Capture Glove is a high-precision data glove for capturing hand and finger movements for teleoperation, robotics, motion capture, and virtual reality applications. Using 15 high-resolution magnetic encoders, the glove captures all finger and wrist movements in real time and wirelessly transmits the motion data to compatible robot systems or simulation environments.
Thanks to the proprietary dynamic mapping algorithm, the captured movements are precisely calibrated and transferred to the target robot. This makes the Motion Capture Glove ideal for the remote control of intelligent robots, research applications, digital twins, VR/AR systems, and industrial automation.
The wireless 2.4 GHz communication enables low-latency data transmission, while the integrated vibration motor provides haptic feedback, improving precision and the overall operating experience in teleoperation applications.
Technical Data
Product type Motion capture glove
Manufacturer Linkerbot
Application areas Teleoperation, robotics, motion capture, VR, AR, research, intelligent manufacturing
Supported Linker Hand models O7, L10, L20, L25
Motion capture 15 high-precision magnetic encoders
Sensors per finger Base joint flexion angle, lateral angle, fingertip flexion angle
Calibration Dynamic real-time mapping algorithm
Data transmission 2.4 GHz wireless connection
Communication protocol UDP
Data acquisition 2.4 GHz WLAN terminal
Range up to 20 m (indoors), up to 40 m (outdoors with clear line of sight)
Pairing One receiver board supports up to two gloves (1:1 or 1:2)
Battery 2,000 mAh lithium battery
Battery life over 8 hours
Charging time approx. 2 hours
Charging port Micro-USB
Haptic feedback Integrated vibration motor
Supported simulators PyBullet, Isaac Sim, MuJoCo
Supported interfaces ROS Topic, ROS2 Topic, Python
SDK C++
Compatible software 3ds Max, Autodesk Maya, Blender
Application examples Teleoperation, motion capture, robot control, simulation, digital twin
Scope of Delivery
  • 1 × Linkerbot Motion Capture Glove
  • 1 × Wireless receiver
  • 1 × USB charging cable
  • 1 × User manual
  • SDK and software (download, depending on manufacturer availability)
€ 4.758,81
