Luxonis DepthAI OAK-D-Pro W (OV9782)
  • SKU: MBS-SES-188-04
  • GTIN: 0618455044250
  • HAN: OAK-D-Pro-W-97
  • Category: 3D Machine Vision
Luxonis DepthAI OAK-D Pro W
  • 3D-Stereo Camera & OnBoard Image Processing
  • Based on Intel® Movidius™ Myriad™ X
  • 2 x 1280 x 720 Stereo Camera & 4K RGB Camera
  • First usage in < 30 Sekunden
  • USB-C Connection
The Luxonis DepthAI boards combine stereo or RGB cameras with the Intel® Movidius™ Myriad™ X platform. The result is a small board that can be used either stand-alone or with an additional device such as an NVIDIA Xavier Jetson, Raspberry Pi or many more. Due to the high performance Intel uC with a base clock of 700MHz this small & compact development board can calculate about 4.5 million possibilities in less than a second.
Differences between OAK-D & OAK-D-Pro?
The differences between both models are just the IR lED & Projector which is integrated in the OAK-D-Pro. With this small module ýou will be able to create high quality point clouds with low or no light conditions.
What's the concept behind Luxonis?
The manufacturer wants to create a versatile platform with an extremely small form factor, on the basis of which anyone can execute a first basic script in less than 30 seconds. The development platforms are available in different configurations, such as with WLAN or a Raspberry PI Compute Module. If the first tests are promising, Luxonis also offers only the pure bare PCB's, which can be integrated as an OEM into a third party component.
What is DepthAI?
Every Luxonis development board is based on the DepthAI Firmware which has already the following features implemented:
  • Neural Inference (e.g. object detection, image classification, etc., including two-stage)
  • Stereo Depth (including median filtering)
  • 3D Object Localization (augmenting 2D object detectors with 3D position in meters)
  • Object Tracking (including in 3D space)
  • H.264 and H.265 Encoding (HEVC, 1080p & 4K Video)
  • JPEG Encoding
  • MJPEG Encoding
  • Warp/Dewarp
  • USB-C port for communication us power supply, supports USB 2 and USB 3 (5Gpbs/10Gpbs)
  • IR illumination LED: perception of dimly lit environments
  • IR laser point projector (active stereo): improves depth perception
  • 4 TOPS processing power (1.4 TOPS for AI)
  • Execution of any AI models
  • Encoding: H.264, H.265, MJPEG - 4K/30fps, 1080/60fps
  • Stereo depth perception: 120fps with filtering
  • Sensor: OV9782
  • DFOV/HFOV/VFOV: 150°/127°/79,5°
  • Resolution: 1MP (1280x800)
  • Focus: FF: 19,6cm - infinity
  • Max. Framerate: 60fps
Delivery Content
  • 1 x Luxonis DepthAI OAK-D-Pro W
  • USB-CA-1m Cable
  • Y-Adapter
Shipping weight: 0,50 kg
Item weight: 0,10 kg
€ 535,95
Others also bought:
