Luxonis OAK SoM Pro S3
- SKU: MBS-SES-275
- GTIN: 0618455050077
- HAN: OAK-SoM-Pro-S3
- Category: 3D Machine Vision
Manufacturers:
- zwei two 100pin 10Gbps connectors
- 2x 100pin mezzanine connectors
- 2x 4-lane and 2x 2-lane MIPI RX lines
- 3.0 TOPS for AI
The OAK-SoM Pro S3 has a quad-core ARM CPU and the Robotics Vision Core 3. The dimensions and pinout are the same as the OAK-SoM Pro, so it can be easily integrated into OAK cameras. It is perfectly suited for use in industrial automation, robotics and security systems.
Primarily, the OAK-SoM Pro S3 was developed for evaluation and backward compatibility. For new products, the OAK-SoM Max is recommended.
This module is based on the RVC3
- 3.0 TOPS for AI
- Imaging: ISP, max. 6 cameras, 500 MP/s HDR, 3A
- executes any AI model, including self-developed models
- Encoding/Decoding: H.264, H.265, MJPEG - 4K/30fps, 1080P/60fps
- Computer vision: warp/dewarp, resizing, cropping, edge detection, object tracking
- Stereo depth perception with filtering, post-processing, RGB depth matching, and high configurability
- Object tracking: 2D and 3D tracking
- Dimensions: 30x45x4 mm
- Weight: 5g
- Interface to the system: two 100pin 10Gbps connectors (DF40C-100DP-0.4V (51))
- Connectors: 2x 100pin mezzanine connectors with the same pinout as OAK-Som Pro
- RAM: 2x DDR RAM due to size/form factor restrictions
- Supported boot modes: NOR, eMMC, USB, Ethernet (EEPROM)
- Supported SD cards
- USB 3.1 Gen 2
- 1x Luxonis OAK SoM Pro S3
| Item information | Value |
| Shipping weight: | 0,10 kg |
| Item weight: | 0,01 kg |
