MAUCH 021 BEC PL 4-14S HYB-BEC / 1x 5.3V
MAUCH PL BEC
  • CubePilot BEC Module
  • Input: 2-6S / 4-14S (version dependent)
  • Output voltage: 5.0, 5.3 & 12V (version dependent)
  • Output current: 1-3A (version dependent)
The MAUCH PL BEC's convince by a high voltage input range at high power outputs of up to 155W. The PL series allows input voltages between 2-6S, whereas the HYB products support 4-14S. In addition, the MAUCH BEC modules convince with low ripple, compact design and reverse polarity protection, so that all components are now protected against reverse polarity and voltage peaks.
The MACUH BEC modules are delivered without CubePilot connection cable. Please add a snap-compatible cable to your order:
  • 041: DF13-6p -> CubePilot 1 / APM... etc.
  • 042: Molex Clik-Mate 2.0 - 6p -> CubePilot 2.1
  • 043: JST-GH-6p -> CubePilot 3... etc
To view the technical data, please select the desired BEC module from the drop-down menu above.
  • MAUCH BEC
  • CFK housing/cover
€ 95,95
