Pixhawk Digital Airspeed Sensor
  • SKU: MBS-SES-43
  • GTIN: 0089336484272
  • HAN: 19003
  • Category: Sensors
  • Pixhawk Pix32 & PX4 compatible
  • I2C Bus
  • 24bit Signal
The Digital Airspeed Sensor is an digital sensor that is Pixhawk compatible. The pressure of the incoming air is used to calculate the speed. The sensor is based on a 4525DO with 1psi measuring range, allowing it to measure speeds between 100m/s to 360km/h.
The implemented I2C Bus enables an easy commissioning. The sensor only has to be plugged into a free port.
  • Digital Airspeed Sensor
  • Silicone hose
  • Pilot pipe
  • I2C Cable
Shipping weight: 0,02 kg
Item weight: 0,02 kg
€ 76,95
