MAUCH 071 HS-050-LV Sensor Board
MAUCH HS Sensor Board
  • Voltage: 6S (28V)
  • Current: 50A
  • Optimized for the Pixhawk The Cube Series (Orange Cube, Black Cube and many more)
The MAUCH HS Sensor Board can reliably measure voltages up to 60V or currents up to 200A depending on the version. The acquired data is then immediately forwarded to Pixhawk FC, which makes an emergency landing if the voltage or current consumption is too low or too high, indicating an error, or requests the pilot to make an emergency landing.
To use the Sensor Board, a MAUCH BEC is required, which supplies the sensor, the Pixhawk, GPS, telemetry and many more with power.
  • MAUCH 071 HS-050-LV Sensor Board
€ 66,95
