MAUCH 076 HS-200-HV Sensor Board
MAUCH HS Sensor Board
  • Voltage: 14S (60V)
  • Current: 200A
  • Optimized for the CubePilot The Cube Series (Orange Cube, Black Cube and many more)
The MAUCH HS Sensor Board can reliably measure voltages up to 60V or currents up to 200A depending on the version. The acquired data is then immediately forwarded to CubePilot FC, which makes an emergency landing if the voltage or current consumption is too low or too high, indicating an error, or requests the pilot to make an emergency landing.
To use the Sensor Board, a MAUCH BEC is required, which supplies the sensor, the CubePilot, GPS, telemetry and many more with power.
  • MAUCH 076 HS-200-HV Sensor Board
€ 80,95
