MAUCH Sensor Hub X2
MAUCH Sensor Hub
  • Monitoring of two Sensor Boards
  • Current & voltage monitoring
  • Uniform discharge of two batteries
MAUCH 010 = PL Sensor Boards (001-004)
MAUCH 080 = HS Sensor Boards (071-076)
The MAUCH Sensor Board is designed to connect two Sensor Boards and monitor the current & voltage of the batteries. The Sensor Board is connected to the alarm I/O of the FC/Pixhawk and alerts the pilot immediately if there is a difference of 15%, so that the pilot can immediately carry out the landing or check the batteries.
  • MAUCH 010 = PL Sensor Boards (001-004)
  • MAUCH 080 = HS Sensor Boards (071-076)
  • MAUCH Sensor Hub X2
from
€ 79,95
  • Available immediately
