Makera 6061 Aluminum Block 50mm * 50mm-100mm
  • various sizes available
  • Ideal for Makera Carvera
6061 Aluminum is a highly versatile and widely-used alloy, known for its exceptional blend of mechanical characteristics and resistance to corrosion.
It is known for its good machinability, making it a go-to choice for CNC machining. It can be easily cut, milled, or turned, allowing for complex and precision components to be manufactured effectively.
Available Sizes:
Thicknesses:
  • 100mm
  • 200mm
Dimensions
  • 35mm * 35mm
  • 50mm * 50mm
The Makera 6061 aluminum sheet plate is ideal for a variety of applications where strength, lightness, and durability are required.
Dimensions
Length
€ 21,95
