Makera Carvera Air CNC Milling Machine
Makera Carvera Air
  • Fresatrice CNC da tavolo compatta con precisione professionale
  • Area di lavoro: 300 × 200 × 130 mm (opzionale 4 assi: Ø 92 × 200 mm)
  • Mandrino: 200 W, fino a 13.000 giri/min
  • Meccanica di precisione: viti a ricircolo di sfere e guide lineari
  • Materiali: legno, plastiche, alluminio, ottone
  • Cambio utensile manuale rapido
  • Software: Makera CAM, Fusion 360, VCarve Pro, e altri
  • Accessori opzionali: modulo laser, modulo rotativo a 4 assi
Precision in a Compact Design
The Makera Carvera Air is a powerful desktop CNC mill that combines precision, versatility, and ease of use in a space-saving design – ideal for makers, educational institutions, and small workshops.
Technical Specifications
  • Working Area (3-Axis): 300 × 200 × 130 mm
  • Working Area (4-Axis): Ø 92 mm × 200 mm
  • Spindle Power: 200 W, up to 13,000 RPM
  • Motor Resolution: 0.005 mm
  • Mechanics: Ball screws and linear guides
Versatile Material Processing
Suitable for wood, plastics, aluminum, brass, and other soft metals – perfect for prototypes and small series production.
Easy Operation
Manual quick tool change and intuitive software such as Makera CAM, Fusion 360, or VCarve Pro make it easy to get started.
Professional-Level Precision
Precise movements thanks to high-quality linear guides and ball screws with high runout accuracy under 0.01 mm.
Recommended For
  • Makers and hobby workshops
  • Small series production
  • Educational institutions
  • Product development and prototyping
  • Creative wood and metalworking
Scope of Delivery
  • 1× Makera Carvera Air CNC milling machine
  • 1× Phone/Tablet holder
  • 1× Dust extraction hose with dust hood
  • 1× Air tube with blower head
Note: Operation requires an external vacuum cleaner and an air compressor (≥ 3.5 bar). Optionally expandable with laser module or 4-axis rotary module.
Shipping weight: 48,00 kg
Item weight: 30,00 kg
€ 3.499,95
