Makera 6061 Aluminum Sheet Plate
  • Various sizes available
  • Ideal for Makera Carvera
The Makera 6061 aluminum sheet plate is an extremely versatile and widely used alloy material, known for its outstanding combination of mechanical properties and corrosion resistance.
Thanks to its good machinability, it is the first choice for CNC machining. It can be easily cut, milled, or turned, allowing the efficient production of complex and precise components.
Available Sizes:
Thicknesses:
  • 3mm
  • 4mm
  • 5mm
  • 10mm
Dimensions
  • 100mm x 150mm
  • 150mm x 200mm
The Makera 6061 aluminum sheet plate is ideal for a variety of applications where strength, lightness, and durability are required.
Thickness
Dimensions
from
€ 9,95
  • Available immediately
