Makera Chamfering Bit - 1/8 Shank
Makera Chamfering Bit - 1/8″ Shank
  • Wood
  • Plastics
  • Composites
  • Non-ferrous Metals
The Makera Thread Milling Bit is a highly precise tool, ideal for machining various materials such as wood, plastics, composite materials, and non-ferrous metals. With its robust shank diameter of 3.175 mm and a total length of approximately 38 mm, this tool offers both stability and flexibility in use.
Specifications:
  • Shank Diameter: 3.175 mm
  • Total Length: ~ 38 mm
  • Material: Solid Carbide
Suitable Materials:
Wood
Plastics
Composite materials
Non-Ferrous Metals
Tool Reference Parameters:
The following parameters apply for different materials:
Tools Aluminum Brass Carbon Fiber Copper Hardwood PCB Plastic Softwood
0.1 mm * 90° Chamfer RPM: 12,000
Feed: 600
PFeed: 200
DOC: 0.2
RPM: 12,000
Feed: 500
PFeed: 200
DOC: 0.1
RPM: 12,000
Feed: 500
PFeed: 200
DOC: 0.1
RPM: 12,000
Feed: 500
PFeed: 200
DOC: 0.1
RPM: 12,000
Feed: 1,000
PFeed: 500
DOC: 1
RPM: 12,000
Feed: 500
PFeed: 200
DOC: 0.1
RPM: 12,000
Feed: 1,000
PFeed: 500
DOC: 1
RPM: 12,000
Feed: 1,200
PFeed: 500
DOC: 2
Package Contents:
  • 1x Makera Thread Milling Bit – Shank Diameter 1/8"
The Makera Thread Milling Bit offers excellent performance and durability for demanding machining tasks and is a valuable addition to any workshop.
Shipping weight: 0,10 kg
Item weight: 0,10 kg
€ 12,95
