Makera Clear Polycarbonate Sheet Plate
  • various sizes
  • Ideal for Makera Carvera
Polycarbonate is a tough, transparent thermoplastic known for its exceptional strength, resilience, and temperature resistance.
Polycarbonate is one of the strongest plastics, offering impact resistance nearly 200 times greater than glass. This material doesn't crack or shatter under extreme conditions, making it ideal for safety and security applications.
Polycarbonate is relatively easy to machine and can be cut, drilled, or formed without the risk of cracking or fracturing. However, it's important to note that the material is sensitive to scratches and abrasions, so care should be taken during the machining process.
Thicknesses:
  • 3mm
  • 4mm
  • 5mm
  • 10mm
Dimensions:
  • 100mm * 150mm
  • 150mm * 200mm
Thickness
Dimensions
from
€ 6,99
  • Available immediately
