Makera Single Flute Engraving Bit for Metal - 1/8 Shank 60º * 0.1mm
- SKU: MBS-MAK-07-01
- GTIN: 6977641140867
- HAN: AAAADAI00501
- Category: CNC Milling Maschines & Accessories
Manufacturers:
Makera Single Flute Engraving Bit for Metal - 1/8? Shank
- Shank Diameter: 3.175 mm
- Total Length: ~ 38 mm
- Material: Solid Carbide
Product Description:
The Single Flute Engraving Bit typically features a single cutting edge that extends from the tip of the bit. This singular flute creates a clean, well-defined edge in the material being engraved, making it ideal for intricate detailing.
Specifications:
Applications:
PCB trace isolating, curve surface milling, relief milling, small text engraving, etc.
Materials:
Wood, plastics, composite materials, non-ferrous metals, PCB, etc.
Tool Reference Parameters:
* RPM: Spindle speed (RPM)
* Feed: Feed rate (mm/min)
* PFeed: Plunge feed rate (mm/min)
* DOC: Depth of cut (mm)
Tool Table:
| Tools | Aluminum | Brass | Carbon Fiber | Copper | Hardwood | PCB | Plastic | Softwood |
| 0.1mm*60° Engraving (Metal) | RPM: 12000 Feed: 500 PFeed: 200 DOC: 0.2 |
RPM: 12000 Feed: 300 PFeed: 100 DOC: 0.1 |
- | RPM: 12000 Feed: 300 PFeed: 100 DOC: 0.1 |
RPM: 12000 Feed: 1000 PFeed: 500 DOC: 1 |
RPM: 12000 Feed: 500 PFeed: 200 DOC: 0.1 |
RPM: 12000 Feed: 1000 PFeed: 500 DOC: 2 |
| 0.2mm*30° Engraving (Metal) | RPM: 12000 Feed: 500 PFeed: 200 DOC: 0.2 |
| 0.3mm*30° Engraving (Metal) | RPM: 12000 Feed: 500 PFeed: 200 DOC: 0.2 |
| 0.4mm*30° Engraving (Metal) | RPM: 12000 Feed: 500 PFeed: 200 DOC: 0.2 |
| 0.5mm*30° Engraving (Metal) | RPM: 12000 Feed: 500 PFeed: 200 DOC: 0.2 |
Scope of delivery:
- 1x Single Flute Engraving Bit - depending on selection
| Item information | Value |
| Shipping weight: | 0,13 kg |
| Item weight: | 0,10 kg |
