Makera Single Flute Engraving Bit - 1/8 Shank 30º * 0.1mm (10pcs)
Makera Single Flute Engraving Bit - 1/8? Shank
  • Shank Diameter: 3.175mm
  • Total Length: ~ 38mm
  • Material: Solid Carbide
Product Description:
The Single Flute Engraving Bit typically features a single cutting edge that extends from the tip of the bit. This singular flute creates a clean, well-defined edge in the material being engraved, ideal for intricate detailing.
Specifications:
Shank Diameter: 3.175 mm
Total Length: ~ 38 mm
Applications:
PCB trace isolating, curve surface milling, relief milling, small text engraving, etc.
Materials:
Wood
Plastics
Composite materials
Non-ferrous metals
PCB, etc.
Tool Reference Parameters:
* RPM: Spindle speed (RPM)
* Feed: Feed rate (mm/min)
* PFeed: Plunge feed rate (mm/min)
* DOC: Depth of cut (mm)
Tool Table:
Tools Aluminum Brass Carbon Fiber Copper Hardwood PCB Plastic Softwood
0.1mm*60° Engraving (Metal) RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.2
RPM: 12000
Feed: 300
PFeed: 100
DOC: 0.1
- RPM: 12000
Feed: 300
PFeed: 100
DOC: 0.1
RPM: 12000
Feed: 1000
PFeed: 500
DOC: 1
RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.1
RPM: 12000
Feed: 1000
PFeed: 500
DOC: 1
RPM: 12000
Feed: 1000
PFeed: 500
DOC: 2
0.2mm*30° Engraving (Metal) RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.2
RPM: 12000
Feed: 300
PFeed: 100
DOC: 0.1
- RPM: 12000
Feed: 300
PFeed: 100
DOC: 0.1
RPM: 12000
Feed: 1000
PFeed: 500
DOC: 1
RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.1
RPM: 12000
Feed: 1000
PFeed: 500
DOC: 1
RPM: 12000
Feed: 1000
PFeed: 500
DOC: 2
0.3mm*30° Engraving (Metal) RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.2
RPM: 12000
Feed: 300
PFeed: 100
DOC: 0.1
- RPM: 12000
Feed: 300
PFeed: 100
DOC: 0.1
RPM: 12000
Feed: 1000
PFeed: 500
DOC: 1
RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.1
RPM: 12000
Feed: 1000
PFeed: 500
DOC: 1
RPM: 12000
Feed: 1000
PFeed: 500
DOC: 2
0.4mm*30° Engraving (Metal) RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.2
RPM: 12000
Feed: 300
PFeed: 100
DOC: 0.1
- RPM: 12000
Feed: 300
PFeed: 100
DOC: 0.1
RPM: 12000
Feed: 1000
PFeed: 500
DOC: 1
RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.1
RPM: 12000
Feed: 1000
PFeed: 500
DOC: 1
RPM: 12000
Feed: 1000
PFeed: 500
DOC: 2
0.5mm*30° Engraving (Metal) RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.2
RPM: 12000
Feed: 300
PFeed: 100
DOC: 0.1
- RPM: 12000
Feed: 300
PFeed: 100
DOC: 0.1
RPM: 12000
Feed: 1000
PFeed: 500
DOC: 1
RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.1
RPM: 12000
Feed: 1000
PFeed: 500
DOC: 1
RPM: 12000
Feed: 1000
PFeed: 500
DOC: 2
Scope of delivery:
  • 1x Makera Spiral 'O' Single Flute Engraving Bit - 1/8? Shank, depending on selection
Shipping weight: 0,35 kg
Item weight: 0,30 kg
Größe
€ 45,95
