Makera TiN Coating Drill Bit - 1/8 Shank 1mm * 10mm (10pcs)
Makera TiN Coating Drill Bit - 1/8″ Shank
  • Shank Diameter: 3.175 mm
  • Drill Diameter: 0.2 mm - 3.175 mm
  • Total Length: ~ 38 mm
  • Material: TiN-coated Solid Carbide
Product Description for Makera TiN Coated Drill Bit - 1/8" Shank
The Makera TiN Coated Drill Bit offers high precision and durability when working with a variety of materials. With a shank diameter of 3.175 mm and a drill diameter ranging from 0.2 mm to 3.175 mm, this drill bit is versatile and ideal for precise drilling tasks. The TiN coating on the solid carbide ensures extended tool life and reduces wear.
Specifications:
  • Material: TiN Coated Solid Carbide
Suitable Materials:
This drill bit is ideal for working with:
  • PCB
  • Wood
  • Plastics
  • Composite Materials
  • Non-Ferrous Metals
Tool Reference Parameters:
  • RPM: Spindle Speed (RPM)
  • Feed: Feed Rate (mm/min)
  • PFeed: Plunge Feed Rate (mm/min)
  • DOC: Depth of Cut (mm)
Lieferumfang:
  • 10x TiN Coating Drill Bit - 1/8″ Shank (je nach Auswahl)
Shipping weight: 0,50 kg
Item weight: 0,45 kg
Größe
€ 56,95
