Makera Two Flute Ball Nose Bit for Metal - 1/8 Shank
Product Description:
The Two Flute Ball Nose Bit allows for carving complex three-dimensional shapes, making undercuts, or machining parts with intricate surface detail.
Specifications:
Shank Diameter: 3.175 mm
Total Length: ~ 38 mm
Material: Solid Carbide
Applications:
Curve surface milling, Relief milling, etc.
Materials:
Wood
Plastics
Composite materials
Non-Ferrous Metals
Tool Reference Parameters:
* RPM: Spindle speed (RPM)
* Feed: Feed rate (mm/min)
* PFeed: Plunge feed rate (mm/min)
* DOC: Depth of cut (mm)
Specifications:
Applications:
Materials:
Wood
Plastics
Composite materials
Non-Ferrous Metals
Tool Table:
Tools Aluminum Brass Carbon Fiber Copper Hardwood PCB Plastic Softwood
1*3mm ball nose (Metal) RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.2
RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.1
- RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.1
RPM: 12000
Feed: 500
PFeed: 200
DOC: 1
- RPM: 12000
Feed: 500
PFeed: 200
DOC: 1
RPM: 12000
Feed: 500
PFeed: 200
DOC: 2
1.5*4.5mm ball nose (Metal) RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.2
RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.1
- RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.1
RPM: 12000
Feed: 500
PFeed: 200
DOC: 1
- RPM: 12000
Feed: 500
PFeed: 200
DOC: 1
RPM: 12000
Feed: 500
PFeed: 200
DOC: 2
2*6mm ball nose (Metal) RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.2
RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.1
- RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.1
RPM: 12000
Feed: 500
PFeed: 200
DOC: 1
- RPM: 12000
Feed: 500
PFeed: 200
DOC: 1
RPM: 12000
Feed: 500
PFeed: 200
DOC: 2
2.5*7.5mm ball nose (Metal) RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.2
RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.1
- RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.1
RPM: 12000
Feed: 500
PFeed: 200
DOC: 1
- RPM: 12000
Feed: 500
PFeed: 200
DOC: 1
RPM: 12000
Feed: 500
PFeed: 200
DOC: 2
3.175*10mm ball nose (Metal) RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.2
RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.1
- RPM: 12000
Feed: 500
PFeed: 200
DOC: 0.1
RPM: 12000
Feed: 500
PFeed: 200
DOC: 1
- RPM: 12000
Feed: 500
PFeed: 200
DOC: 1
RPM: 12000
Feed: 500
PFeed: 200
DOC: 2
Scope of delivery:
  • 1x Makera Two Flute Ball Nose Bit for Metal - 1/8″ Shank
Shipping weight: 0,10 kg
Item weight: 0,10 kg
Größe
€ 23,97
  • Available immediately
