Marvelmind Super Beacon Outdoor 868MHz/915MHz + IMU
  • SKU: MBS-SES-55
  • Category: Sensors
Marvelmind Super Beacon Outddor + IMU
  • IPx7 Protected (30min into 1m water)
  • Frequency: 868MHz (EU) & 915MHz (USA)
  • Integrated IMU
  • 3D Accel. & 3D Gyro.
  • designed for up to 1000m²
The Marvelmind Beacon is one of two parts that enable precise indoor navigation with a tolerance of only 1-3% / ±2cm, the other part that is required is the Marvelmind modem. The system is designed to precisely make out the position of both UAV's & AGV's, but also of other objects that have a beacon attached to it. The Marvelmind system is based on an 868MHz/915MHz frequency combined with the latency of ultrasonic sensors.
Special Features
  • 3D Positioning if 3 Beacons are used
  • 2D Positioning if 2 Beacons are used
  • recommended distance 30m | capable of up to 50m
  • Integrated IMU
Technical Data
  • Space: < 1000m²
  • Tolerance: ±2cm
  • Localisation speed: 0,05 - 25Hz
  • Working voltage: 1000maH Lipo
  • Weight: 59 Grams (incl. Battery, Antenna and Case - without 27g)
  • Dimensions: 55 x 55 x 33mm
  • incl. Antenna: 55 x 55 x 65mm
  • 1 x Super Beacon Outdoor + IMU incl. Antenna
The user manual, configuration example aswell as additional technical data can be found HERE.
Shipping weight: 0,08 kg
Item weight: 0,06 kg
Frequenz
€ 229,95
  • Available immediately
