MightyZAP Molex Connector 10 Housing + Terminals
  • TTL/PWM: 30 Terminals
  • RS485: 40 Terminals
The IR-MC02 is a Molex connector set for assembling custom TTL/PWM cables for mightyZAP actuators. Supplied as bulk goods with 10 housings (3-pin) and 30 crimp terminals – ideal for users who want to customize their wire harnesses in length and configuration.
The set covers the standard connector requirements for mightyZAP families with a TTL or PWM interface. A crimping tool for Molex contacts and experience in wire harness assembly are required. Pay close attention to correct polarity and clean crimping to avoid mis-wiring or contact failure.
Technical Data
Item IR-MC02
Interface TTL / PWM
Housing Molex 3-pin male housing (05037-5033) – 10 pcs
Terminals Molex 3-pin male terminal (00870-1039) – 30 pcs
Packaging Bulk
Manufacturer / origin IR Robot Co., Ltd. / Korea
Product Features
  • Original parts for assembling mightyZAP cables (TTL/PWM)
  • 10 housings with spare terminals (30 pcs) for crimping losses
  • Bulk packaging – ideal for small batches and repair
Scope of Delivery
  • 10× Molex 3-pin male housing (05037-5033)
  • 30× Molex 3-pin male terminal (00870-1039)
Note: A suitable crimping tool for Molex contacts is required for assembly. When making your own cables, ensure the correct pin assignment (according to the mightyZAP data sheet) to avoid damage to the actuator.
The IR-MC03 is a Molex connector set for assembling custom RS-485 cables for mightyZAP actuators. Supplied as bulk goods with 10 housings (4-pin) and 40 crimp terminals – ideal for users who want to customize their wire harnesses in length and configuration.
The set covers the standard connector requirements for mightyZAP families with an RS-485 interface. A crimping tool for Molex contacts and experience in wire harness assembly are required. Pay close attention to correct polarity and clean crimping to avoid mis-wiring or contact failure.
Technical Data
Item IR-MC03
Interface RS-485
Housing Molex 4-pin male housing – 10 pcs
Terminals Molex male terminal – 40 pcs
Packaging Bulk
Product Features
  • Original parts for assembling mightyZAP cables (RS-485)
  • 10 housings with spare terminals (40 pcs) for crimping losses
  • Suitable for multidrop wiring of RS-485 mightyZAP actuators
Scope of Delivery
  • 10× Molex 4-pin male housing
  • 40× Molex 4-pin male terminal
Note: The exact Molex part numbers for the housing and terminals of the IR-MC03 are not explicitly stated on the manufacturer's product page; the set corresponds to the standard 4-pin configuration for the RS-485 variant. A suitable crimping tool for Molex contacts is required for assembly. When making your own cables, ensure the correct pin assignment (according to the mightyZAP data sheet).
RS485 or TTL/PWM
Price on request
  • Must be ordered. Ready for shipment in 30 days after order.
