NVIDIA Jetson AGX Xavier Industrial Module (32GB)
  • SKU: MBS-ENTB-94
  • GTIN: 0658917501778
  • HAN: 900-82888-0080-000
  • Up to 20x the performance and 4x the memory of the Jetson TX2i
  • Suitable for industrial and/or safety certified AI products
  • JetPack SDK
  • 32GB 256-Bit LPDDR4x
  • 30 TOPS (INT8)
NVIDIA's Jetson AGX Xavier Industrial Module delivers the highest performance for embedded industrial functional and AI security applications in a stable and power-efficient form factor. This system-on-module enables the latest AI models to be used for demanding applications, thanks to up to 20x the performance and up to 4x the memory of the Jetson TX2i. The model is suitable for industrial and/or safety-certified AI products because it has an extended temperature range, shock and vibration specifications, and new functional safety features monitored by Safety Cluster Engine. It also has hardware-verified secure boot, hardware-accelerated cryptography, encrypted memory support, and other security features to protect customer sofwares.
Because of the NVIDIA JetPack SDK and pre-trained models from the NGC catalog, time and cost savings are realized for production AI software development. Included in JetPack are: Linux driver package (L4T), libraries to accelerate all major AI frameworks, as well as computer vision, graphics, multimedia, etc., and the latest NVIDIA software development tools.
During the 10-year life of the module, cloud-native technologies ensure smooth model and software updates.
  • AI Performance: 30 TOPS (INT8)
  • GPU: NVIDIA Volta Architecture with 512 NVIDIA CUDA cores and 64 Tensor cores
  • Max. GPU Frequency: 1.21 GHz
  • CPU: 8-core NVIDIA Carmel Arm v8.2 64-bit CPU 8MB L2 + 4MB L3
  • CPU Max. Frequency: 2.03 GHz
  • DL Accelerator: 2x NVDLA
  • Vision Accelerator: 2x 7-way VLIW Vision processor
  • Safety cluster engine: 2x ARM Cortex R5 in lockstep
  • Memory: 32GB 256-bit LPDDR4x 136,5 GB/s
  • Storage: 64GB eMMC 5.1
  • Power: 20W - 40W
  • Voltage Input: 5V, 9V ~ 20V
  • PCIe: 1 x8 + 1 x4 + 1 x2 + 2 x1 (PCIe Gen4, Root port and endpoint)
  • CSI Camera: up to 6 cameras (36 via virtual channels) | 16 lanes MIPI CSI-2 | D-PHY 1.2 (up to 40Gbps) | C-PHY 1.1 (up to 62Gbps)
  • Video Encode: 2x4K60 | 6x4K30 | 12x1080p60 | 24x1080p30 (H.265&H.264);  1x4K60 | 2x4K30 | 6x1080p60 | 14x1080p30 (VP9)
  • Video Decode: 2x8K30 | 4x4K60 | 8x4K30 | 18x1080p60 | 36x1080p30 (H.265); 2x4K60 | 6x4K30 | 12x1080p60 | 24x1080p30 (H.264&VP9)
  • Display: 3 multi-mode DP 1.4/eDP 1.4/HDMI 2.0 a/b
  • Networking: 10/100/1000 Base-T Ethernet
  • USB: 3x USB 3.1 (10Gbps) and 4x USB 2.0
  • Other IOs: 5x UART, 3x SPI, 3x 12S, 5x 12C, 2x CAN, DMIC & DSPK, GPIOs
  • Dimension: 100mm x 87mm, 699-pin connector
  • Operating temperature: -40 C to 85 C measured on the TTP surface
  • Storage temperature: -40° C to 85° C
  • Non-operational humidity: 95% RH, -10°C to 65°C
  • Operational vibration: 5G RMS 10 to 500Hz, 3-axis, FCT (random/sinusoidal)
  • Non-operational vibration: 3G RMS 10 to 1000Hz, 3-axis, FCT (random)
  • Operational shock: 50G, half sine, 11ms
  • Non-operational shock:140G, half sine, 2ms
  • 1x NVIDIA Jetson AGX Xavier Industrial Module
Others (1)
NVIDIA Jetson Download Center
€ 1.944,95
Docs MYBOTSHOP documentation
