NVIDIA Jetson Nano Module
  • SKU: MBS-ENTB-90
  • GTIN: 0658917501709
  • HAN: 900-13448-0020-000
  • Accelerated processing power of up to 472 GFLOPS
  • NVIDIA Maxwell GPU
  • Comprehensive range of IOs
  • Energy efficient
  • NVIDIA JetPack
The NVIDIA Jetson module provides accelerated computing performance of up to 472 GFLOPS and is capable of running multiple neural networks in parallel. It also supports all popular AI frameworks and finds application in mass-market areas such as AIoT gateways, intelligent network camera and video recorders, consumer robots, and optical inspection systems.
The system-on-module is powered by NVIDIA Maxwell GPU, with 4GB. This enables real-time processing of high-resolution inputs. It has a combination of performance, power advantage, and an extensive selection of IOs, from high-speed CSI and PCIe to low-speed 12Cs and GPIOs. In addition, multiple different sensors are supported to enable a wide range of applications, all with a high power efficiency of 5W.
The Jetson Nano is also supported by NVIDIA JetPack. The JetPack includes a Board Support Package (BSP), a Linux operating system, NVIDIA CUDA, cuDNN and Tensor RTTM software libraries for deep learning, computer vision, GPU computing, multimedia processing, and more. The same JetPack is used across the NVIDIA JetsonTM product family. It is fully compatible with NVIDIA's leading AI platform for AI software training and deployment.
  • GPU: 128-core Maxwell
  • CPU: Quad-core ARM A57 @ 1.3 GHz
  • Memory: 4GB 64-bit LPDDR4 25,6 GB/s
  • Storage: 16GB eMMC 5.1
  • Video Encoder: 4K @ 30 | 4x 1080p @ 30 | 9x 720p @ 30 (H.264/H.265)
  • Video Decoder: 4K @ 60 | 2x 4K @ 30 | 8x 1080p @ 30 | 18x 720p @ 30 (H.264/H.265)
  • CSI: 12 (3x4 or 4x2) lanes MIPI CSI-2 D-PHY 1.1
  • Connectivity: Gigabit Ethernet
  • Display: HDMI 2.0, eDP 1.4 DP 1.2 (two simultaneously)
  • PCIe: 1x1/2/4 PCIe Gen2
  • Others: I2C, I2S, SPI, UART, SD/SDIO, GPIO
  • Mechanical: 69.6 mm x 45 mm 260-pin SODIMM Connector
  • Voltage power: 5V
  • Module power: 5 ~ 10W
  • Operating temperature: -25°C to 80°C
  • Storage temperature: -25°C to 80°C
  • Humidity: 85% RH, 85°C (non-operational)
  • Vibration: Sinusoidal 5G RMS 10 to 500 Hz, random 2,88G RMS, 5 to 500 Hz (non-operational)
  • Shock: 140G, half sine 2 ms Duration (non-operational)
  • 1x NVIDIA Jetson Nano Module
Shipping weight: 0,20 kg
Item weight: 0,02 kg
Contact data
Others (1)
NVIDIA Jetson Download Center
€ 269,95
  • Currently out of stock
