NVIDIA Jetson Orin Nano Module 4GB
  • SKU: MBS-ENTB-93-01
  • GTIN: 0658917501754
  • HAN: 900-13767-0040-000
  • version: 4GB
  • 6-core Arm Cortex-A78AE v8.2
  • System-on-Modul is compatible with Jetson Orin NX
  • Voltage Input: 5V - 20V
The NVIDIA Jetson Orin Nano module has a very small form factor. With the Jetson Orin NX, the system-on-module is pin-compatible and also supports multiple concurrent AI application pipelines with high-speed IO and an NVIDIA Ampere architecture GPU. The module runs the NVIDIA AI software stack and provides application-specific application frameworks, such as Isaac for robotics, Riva for conversational AI, and DeepStream for vision AI. Time savings can be achieved due to NVIDIA Omniverse Replicator for synthetic data generation (SDG) and NVIDIA TAO Toolkit for fine-tuning pre-trained AI models from the NGC catalog.
Technical data 4GB Module
  • AI Performance: 20 TOPS
  • GPU: 512-core NVIDIA Ampere Architecture GPU with 16 Tensor cores
  • Max. GPU Frequency: 625 MHz
  • CPU: 6-core Arm Cortex-A78AE v8.2 64-bit CPU 1.5MB L2 + 4MB L3
  • CPU Max. Frequency: 1.5 GHz
  • Memory: 4GB 64-bit LPDDR5 34 GB/s
  • Camera: Up to 4 cameras (8 via virtual channels*) 8 MIPI CSI-2 lanes D-PHY 2.1 (up to 20Gbps)
  • Video Decode: 1x 4K60 (H.265) 2x 4K30 (H.265) 5x 1080p60 (H.265) 11x 1080p30 (H.265)
  • PCIe: 1 x 4 + 3 x 1 (PCIe Gen3, Root Port and Endpoint)
  • USB: 3x USB 3.2 Gen2 (10Gbps) | 3x USB 2.0
  • Networking: 1x GbE
  • Display: 1x 4K30 multi-mode DP 1.2 (+MST)/eDP 1.4/HDMI 1.4
  • Other IOs: 3x UART, 2x SPI, 2x 12S, 4x 12C, 1x CAN, DMIC & DSPK, PWM, GPIOs
  • Power: 7W - 10W
  • Mechanical: 69,6mm x 45mm, 260-pin SO-DIMM connector
  • 1x NVIDIA Jetson Orin Nano Module
Others (1)
NVIDIA Jetson Download Center
€ 616,95
