Opt Laser Performance Upgrade
- SKU: MBS-OPT-04
- Category: Accessories
Manufacturers:
OPT Laser Performance Upgrade
- High pressure air assist nozzle
- μSpot CNC laser
Opt Laser's performance upgrade includes 2 products: High Pressure Air Assist Nozzle and the μSpot CNC Laser.
High pressure air nozzle details
The High Pressure Air Nozzle is compatible with XF+ laser heads with or without µSpot lens upgrade and is a valuable tool for laser cutting and engraving. It not only increases the speed of laser cutting and engraving by 6.5 times, but also significantly improves the quality of the processed material. With high pressure air nozzles, your performance is greatly improved in quality with consistent and defined characteristics. Our high-pressure air nozzles also protect your optics from smoke and dust particles, extend the intervals between subsequent lens cleanings, and increase user safety. In addition, the length of the high pressure air nozzle can be adjusted for different material thicknesses, with a length of +8/-4 mm for the XF+ laser head and +5/-4 mm for the XF+ laser head with µSpot lens update.
Compatible with all types of XF+ laser heads - Customers who own the new revised XF+ laser head for laser engraving and laser cutting receive a special sleeve that is compatible with the nozzle. Four screw holes ensure compatibility with both the previous generation of µSpot laser heads and the XF+ laser head with the µSpot lens upgrade.
High pressure air flow - The narrow 2.2 mm opening at the outlet compresses the airflow for maximum airflow rate.
Lieferumfang:
- XF+ objective adapter sleeve
- Air line connection (M5 / 4 mm)
- O-ring seal (8x1 FPM)
- Air tube (Ø4mm; 7 m long)
- Lens wrench
- Four M3x3 screws
Details about uSpot Lens Upgrade for PLH3D-6W-XF+
μSpot CNC lasers - designed for industry". Opt Lasers' laser heads have always been characterized by ergonomics, well thought-out solutions and high quality. With μSpot, the Opt Lasers CNC laser range has now been expanded. Thanks to the industry-leading laser beam focus, we achieve a smaller spot size and increase the optical output power by 20%.
μSpot ensures the fastest laser cutting and engraving speeds with a 6W laser, as well as higher engraving resolution. Our new laser engraving head satisfies even the most demanding professionals.
Specification:
- Dimensions: 40 x 55 x 105 mm (1.6 x 1.7 x 5.9 in.)
- Focus distance: 60 mm / 2.362"
- Input voltage: 12 - 24 V
- Max. Power consumption: 30 W
- Noise level: 58 dBA
- Weight: 220g (7.76 oz.)
- Mounting holes type: M3 x 0.5 x 4.5 mm
- Ambient temperature range: 0 - 45°C (32 - 113°F)
- Mounting holes: 4 holes 24 x 15 mm (0.94 x 0.59 in.)
- Modulation input 1: 0 - 5V analog/TTL/PWM
- Modulation input 2: 0 - 24V TTL/PWM
- Max. Modulation bandwidth: 30 kHz
- Laser diode wavelength: 450 nm
- Laser diode optical power: 6 W
- Max. Power density: 680 [kW/cm2]
Scope of delivery:
- 1x uSpot-Laser engraver
