OnRobot Compute Box
  • SKU: MBS-Z1-286
  • GTIN: 05390368407180
  • Category: Accessories
OnRobot Compute Box
  • Complete connection kit for OnRobot tools on the robot arm
  • Communication via Ethernet or digital I/O
  • Easy setup via the web-based OnRobot WebLogic
OnRobot Robot Kit with Compute Box
The OnRobot Robot Kit is the link between your robot arm and OnRobot tools. At its core is the Compute Box: it supplies power to grippers, sensors and tools such as the OnRobot Sander and handles communication with the robot controller.
The Compute Box is connected to the robot controller and, via the 5 m tool cable, to the tool on the robot flange. Communication runs either via Ethernet or digital I/O. The tool is conveniently set up and configured via the web-based OnRobot WebLogic – no additional software installation on the PC required.
Your benefits at a glance
  • Everything in one kit: Compute Box, tool cable, network cable and power supply – ready to use
  • One interface for many tools: for OnRobot grippers, sensors and processing tools
  • Flexible connectivity: communication via Ethernet or digital I/O
  • Easy setup: configuration via the web-based OnRobot WebLogic
  • Compact: the Compute Box can be mounted in a space-saving way in the control cabinet or on the robot cell
Technical specifications
Component OnRobot Compute Box with accessories
Function Control and interface unit between robot controller and OnRobot tool
Communication with robot controller Ethernet or digital I/O
Configuration Via the web-based OnRobot WebLogic (browser on PC)
Tool connection 5 m cable to the Quick Changer on the robot flange
Compute Box dimensions approx. 112 × 100 × 33 mm
Compute Box weight approx. 0.2 kg
Item number W024607
  • 1× OnRobot Compute Box
  • 1× tool connection cable, 5 m
  • 1× network cable
  • 1× power supply
€ 1.084,95
