Orbbec Sync Cables for Femto Mega and Femto Bolt
- SKU: MBS-Z-458
- GTIN: 05390368407173
- HAN: 310600383
- Category: Accesoires
Manufacturers:
- 8-pin sync cable, 1 m
- For Orbbec Femto Mega and Femto Bolt
The Orbbec Sync Cable 8-Pin (1 m) for Femto Mega and Femto Bolt is the matching synchronization cable for multi-camera setups with the Orbbec ToF cameras Femto Mega and Femto Bolt. It plugs into the camera's 8-pin GPIO sync port and connects the camera to the Orbbec Sync Hub Dev.
This allows several cameras to be precisely synchronized via hardware trigger: a primary camera sets the timing, and the secondary cameras capture simultaneously. This is the basis for clean, offset-free 3D data from multiple viewpoints – for example for volumetric capture, body tracking or measuring larger objects.
Ideal for:
- Synchronized multi-camera systems with Femto Mega and Femto Bolt
- Volumetric video capture and 3D scanning from multiple perspectives
- Body tracking and motion analysis with multiple cameras
- Robotics and machine vision applications covering a large area
Key Benefits
- Original Orbbec accessory, designed for Femto Mega and Femto Bolt
- Flat 8-pin cable for the camera's GPIO sync port
- For star and daisy-chain setups with the Orbbec Sync Hub Dev
- Compact 1 m length for tidy camera setups
The ideal addition for anyone who wants to connect several Femto cameras into a precisely synchronized system.
Technical Specifications
| Cable type | 8-pin flat cable (sync) |
| Length | 1 m |
| Compatible cameras | Orbbec Femto Mega, Orbbec Femto Bolt |
| Compatible hub | Orbbec Sync Hub Dev (Star / Daisy Chain) |
| Camera connection | 8-pin GPIO sync port |
| Manufacturer part number | 310600383 |
Scope of Delivery
- 1× Orbbec Sync Cable 8-Pin (1 m) for Femto Mega and Femto Bolt
Cameras and sync hub are not included. One cable is required per camera in the setup.
