Orbbec3D Astra Stereo S U3
  • SKU: MBS-SES-116
  • GTIN: 0096718604081
  • HAN: 100100162
  • Category: Sensors
Orbbec3D Stereo S U3 3D-Camera
  • 1920 x 1080Px
  • RGB & Depth Images up to 30FPS
  • Scan range: 0,2,5 - 2,5m
  • USB Port TYPE C
The Orbbec3D Stereo S is a very small 3D-camera with a high picture resolution of 1920 x 1080 pixel with 30FPS. The depth resolution framerate is 1280 x 800 / 640 x 400Px at 30FPS. The acquired data can be used in multiple ways via the USB Port Type-C. Below are some of the current fields of application listed, that the Orbbec3D Stereo S finds it use:
  • Robotic / Autonomous systems
  • Quality check
  • 3D-Scanner / Full Body Scanner & Handheld
The large spectrum of possible applications is only achievable through the outstanding hardware aswell as well-engineered software and driver packages that also result in the Orbbec Stereo S to be compatible with ROS, OpenNI2, Astra SDK and much more.
The whole sortiment of Orbbec3D software products such as the Windows or Linux driver, the Orbbec3D Unity Engine, or the Body Tracking SDK can be downloaded for free and without any registration needed using the following link: https://orbbec3d.com/develop/
Special Features of the Orbbec3D Stereo S
The Orbbec3D Astra Stereo S if compared with the Embedded S and Astra Mini has the benefit of beeing able to be used outdoor aswell as indoor. But please take note, that the 3D-Camera has no humidity or water protection and is only able to absorb the insolation and therefore take high resolution picture aswell as generating depth resolution data.
  • Depth Images: 1280×800@30FPS | 640×400@60FPS | 640×400@30FPS
  • RGB: 1920×1080@30FPS | 1280×720@30FPS | 640×480@30FPS
  • Depth FOV: H67.9° V45.3° D78°±3.0°
  • RGB FOV: H71.5° V56.7° D84°
  • Dimensions: 65,3 x 22,5 x 12,3mm
  • Scanning range: 0,25 - 2,5m
  • Data transfer & Power: USB
  • Power consumption: < 2,2W
  • 1 x Orbbec Astra Stereo S U3 3D-Camera
Shipping weight: 0,02 kg
Item weight: 0,06 kg
Contact data
PDF (2)
Orbbec Stereo S Datasheet
Orbbec Stereo S Brochure
€ 219,95
  • Item ordered. delivery date not yet announced by the manufacturer
