Phidgets Analog 4-Output
  • SKU: MBS-Z-111
  • GTIN: 0618455045202
  • HAN: 1002_0B
  • Category: Phidgets
  • Voltage: -10V to +10V at max. +/-20mA
  • Voltage resolution: 12 bit (4.8mV)
  • 4 channels share a common ground
This product generates a voltage above -10V to +10V at a maximum of +/-20mA. If this current is exceeded, an error is displayed to indicate that the voltage may have dropped below the setpoint. The voltage is generated with a resolution of 12 bits (4.8mV) for this product. The maximum output frequency depends on the speed of your system.
The board is not isolated and the four channels share a common ground. In addition, the entire power supply is via USB.
  • Phidgets Analog 4-Output
  • 4x M3 screws (2cm)
  • 4x plastic spacers (5mm)
  • 4x M3 nuts
€ 125,95
