Phidgets Isolated 12-bit Voltage Output
  • SKU: MBS-Z-85
  • GTIN: 0618455045127
  • HAN: OUT1001_0
  • Category: Accesoires
  • -10 to 10 Volt
  • 4.9mV (12-bit) resolution
  • Adjustable voltage range
The Phidgets Isolated 12-bit Voltage Output is used whenever a voltage of -10 to 10 volts is required. The resolution is 4.9mV (12-bit) and can also be connected to the VINT HUB via a VINT port. The board is electrically isolated from input and output to ensure a secure application.
Documentation
  • Voltage resolution: (12-bit) 4.9mV
  • Output voltage: ± 10 V
  • Power consumption: 35- 85 mA
  • Dimensions: approx. 42.5 x 30 mm
  • Operating temperature: -40 - 85 °C
  • Phidgets Isolated 12-bit Voltage Output
€ 53,99
