RFD 868/900MHz 6dBi Omni Antenna
  • SKU: MBS-Z1-39
  • GTIN: 0618455050596
  • HAN: ANT-900-6dBi-OMNI-N
  • Category: Accessories
RFDesign Omni Antenna
  • Pixhawk RFD Bundle compatible
  • 900MHz (RFD868x & RFD900x)
  • 6dBi (Factor 6 Gain of the isotropic sphere beam)
The waterproofed omni antenna operates at 900MHz, making it compatible with the RFD868x and RFD900x Telemetry Bundle. As a result of the sophisticated omni design, this antenna provides a transmit/receive power gain by a factor of 6 (six) compared to the isotropic omnidirectional beam.
At the same time this antenna is optimally suited for the setup of a base station/ground station.
What else is required for operation with RFD modems?
To connect the antenna to an RFD Modem, an N-RPSMA adapter and RPSMA(M)-(M) cable is required
  • Antenna type: Omni
  • Frequency: 860MHz - 960MHz
  • Gain: 6dBi
  • Impedance: 50Ohm
  • Dimensions: 860 x 21,7mm
  • Weight: 560g
  • RFDesign 900MHz 6dBi Antenna
Shipping weight: 2,00 kg
Item weight: 0,56 kg
€ 140,95
