RFD 868/900MHz 6dBi Yagi Antenna
  • SKU: MBS-Z1-20
  • GTIN: 0618455050480
  • HAN: ANT-900-YAGI-3EL-6dBi
  • Category: Accessories
RFDesign Yagi Antenna
  • Pixhawk RFD Bundle compatible
  • 900MHz (RFD868x & RFD900x)
  • 6dBi (Factor 6 Gain of the isotropic sphere beam)
The 3-element yagi antenna operates at 900MHz, making it compatible with the RFD868x and RFD900x Telemetry Bundle. As a result of the sophisticated yagi design, this antenna provides a transmit/receive power gain by a factor of 6 (six) compared to the isotropic omnidirectional beam.
At the same time this antenna is optimally suited for the setup of a base station/ground station.
What else is required for operation with RFD modems?
To connect the antenna to an RFD Modem, an N-RPSMA adapter and RPSMA(M)-(M) cable is required
  • Antenna type: Yagi-Uda
  • Elements: 3
  • Frequency: 902MHz - 928MHz
  • Front/Back: 13dB
  • Gain: 6dBi
  • Impedance: 50Ohm
  • Maximum power: 100W
  • Screw hole: 35-50mm
  • Cable length: 250mm
  • Dimensions: 325 x 200 x 55mm
  • Weight: 275g
  • RFDesign 900MHz 6dBi Antenna
Shipping weight: 0,34 kg
Item weight: 0,31 kg
€ 59,99
Docs MYBOTSHOP documentation
