Rotrics DexArm Luxury Kit
  • SKU: MBS-DEX-01-02
  • GTIN: 0049438166704
  • HAN: Rotrics_DexArm_Luxury
  • Category: Robots
  • High-precision robot arm
  • 3D printing
  • 3,5" Touchscreen
  • Phneumatic kit
WITHOUT lasermdul! The laser module can be purchased separately after sending the signed disclaimer!
General
The Rotrics DexArm is a multifunctional robot arm that can be used for a variety of applications. Besides 3D printing, precise gripping, the DexArm can also be used for drawing and painting. You can choose between the Maker and the Luxury Kit according to your application purpose for the DexArm, which includes all the accessories needed for the different applications.
Extension possibilities
In addition to the Maker and Luxury Kit, you can also buy a conveyor belt and a sliding rail kit as an option. This expands the already extensive range of applications even further with the possibility such as simulating production processes or allowing the DexArm to work on larger areas.
Basic Version:
  • Payload: max. 500g
  • Dimensions: 175 x 128 x 315mm
  • Repeatability precision: 0,05mm
  • Speed: max. 500mm/s
  • Axis: 4
  • Precision: 0.1mm
  • Weight: 2,4kg
3D Printing:
  • Build Volume: 220 x 220 x 250mm
  • Layer Resolution: 0.1mm
  • Supported Materials: PLA, ABS, Wood, Carbon Fiber
  • Nozzle Travel Speed: up to 150mm/s
Delivery Content
  • 1 x Rotrics DexArm
  • 1 x Pen Holder Module
  • 1 x 3D Printing Module
  • 1 x Pneumatic Module
  • 1 x Air Pump Box
  • 3 x Suction Cup
  • 3 x Soft Gripper
  • 1 x Touchscreen
  • 1 x Extruder
  • 1 x Build Plate
  • 5 x Printing Sticker & Wood Plate
  • 1 x DC Y Power Splitter
  • 1 x Power Supply
  • 2 x Dual Type-C Cable
  • 1 x Type-C Cable
  • 1 x Tweezers
  • 1 x Backup Nozzle
Shipping weight: 6,37 kg
Item weight: 3,50 kg
Rotrics DexArm Luxury Kit Datasheet
€ 1.219,95
