Rotrics DexArm Rotary Kit
  • SKU: MBS-Z1-61
  • GTIN: 0096718603695
  • Category: Accesoires
  • Enables additional degree of freedom
  • Converts the DexArm from a 3DOF to a 4DOF robotic arm
  • Includes suction cup & 3-finger gripper
With the Rotation Kit, you can turn your DexArm into a 4-DOF robotic arm. The universal adapter design makes it easy to switch between soft gripper, suction cup module and your DIY module. The record button allows you to record the movements of the DexArm in Teach&Play mode. Highlights: 360° rotation 350g payload capacity Easy to assemble, easy to switch between gripper and suction module, Teach&Play button to record movements, External connector for DIY modules.
  • Pulling force: 350g
  • Suction pump: ~35 Kpa
  • Suction cup diameter: 5mm, 10mm, 15mm
  • Soft gripper
  • radius: 30mm
  • Weight: 100g
  • 1 x soft gripper
  • 1 x rotary module
  • 1 x suction stick
  • 1 x Pneumatic connection
€ 141,95
